Shop Sign
0 opens
0 copies
Brian Gidney
Brian Gidney
Arenas Valley, NM
I made a sign for my shop out of 3/4" white Melamine particle board.
MDF Wood
MDF Wood
Dimensions: 18 in × 24 in, Thickness: 3/4 in, Type: MDF
Material Size
I have used signs for my shop that measure 12″ × 24″ to 18″ × 24″. However, I wanted something for inside of the shop so I selected the 12″ × 24″ size. I lay the material onto the waste board and clamp it in.
Select your material in Easel
Next, I open up easel and go to the materials menu and adjust the size to my board and thickness. Then I select the material that is similar to what I am using.
Layout and Show Toolpaths
When laying out my design I like to leave a pretty good size boarder in case I need to square my material to the pictures being carved. I then select the depth of cut and decide if I will be using a two staged cut for detail. To determine this I hit the show tool paths button.
Carve!
280 minutes
Once everything looks nice and everything is at the right measurements and still clamped! I hit the carve button and watch the Xcarve work!
Trim and Finish
After it is all carved I will take this sign to trim and square it on the table saw. After that I am going to paint the letters and background to my liking.
