Sheet Goods Gripper
40 opens
8 copies
Martin Ball
Martin Ball
A handle constructed out of clear acrylic with bolts and suction grip rubber allowing you to easily handle sheet goods either in the workshop or at the job site!
Clear Acrylic Sheet - Cast
Dimensions: 12 in × 24 in - 2014 - 2019, Thickness: 1/2 in, Material Type: Cast
Flat Head Socket Cap Screw
Flat Head Socket Cap Screw - Allen Head - 5M - 30552-01 (x10)
Precision Shim Washer
O.D.: 10mm, I.D.: 5mm, Thickness: 1.0mm +/- 0.076
Press In Threaded Insert
Thread: M5, Qty: 10 Pack, Mounting Hole: 6.35mm
Suction Cup Tape
Suction Cup Tape
Color: White, Form: Sheet, Dimensions: 210 mm × 297 mm × 0.50 mm
$15.99
$15.99
Sanding and drilling the handle section
Once you have carved the two pieces it is time for assembly and finishing.
A light sanding around all edges will help remove any erroneous machining marks and will help the project assemble easier.
You will need to drill two holes on the outside edge of the handle section in order to bolt the insert part to it.
Using a 5.5mm drill bit in your drill press drill all the way through the material at the location shown below.
Drilling the insert section
The project is assembled by drilling and pressing threaded push bolts into the outside edges of the insert part as shown below, to find the centre for these locate the insert plate into the two holes in the handle section and then use a marker through the pre-drilled holes to mark you centre location.
Using a 9.5mm drill bit drill a hole to the depth of 7mm.
Rubber application and final assembly
Push fit two threaded inserts into the holes that have just been drilled.
Cut two pieces of suction material down to 100 × 100mm and affix onto the two inside faces of the two parts.
You can now use the threaded bolt to join the two parts together, ensuring that the rubber surfaces are facing each other.
