Shapeoko 2 Upgrade List
Bart Dring
Bart Dring
This project is the a collection of all the upgrades for a Shapeoko 2.
24v Fan
24v Fan
Voltage: 24 VDC, CFM: 19.8, Size: 60mm × 60m × 25mm, Category: Accessory
3-Axis DSP Based Digital Stepper Driver
Type: 3 Axis Stepper Motor Driver
Bosch Colt PR20EVS Spindle Mount
Material: 6061 Aluminum, Color: Black Anodized, Type: Spindle Mount
Cut2D 1.5
Cut2D 1.5
Type: CAM Software, Version: 1.5
Full kit - 110V Plug, includes electronics and tool set
DeWalt DW660 Spindle Mount
New Property: Spindle Mount, Type: Spindle Mount
Drag Chain
Drag Chain
Type: Drag Chain - 2013 - 2019, Qty: 1m, Link Type: Semi Open
Drag Chain
Drag Chain
Type: Drag Chain Ends - 2013 - 2019, Qty: 2, Link Type: Semi Open
E-Stop Button
E-Stop Button
Type: Latching pushbutton
Enclosed Power Supply
Output Voltage: 24VDC - 2013 - 2018, Current: 6.25A, Power: 150W
ER11-A Collets and Nuts
ER11-A Collet 1/4in
$7.17
gShield Enclosure
gShield Enclosure
Color: Black Anodized Base & Cover
Knurled Aluminum Knob
With crank
Microswitch
Microswitch (×3)
Type: Microswitch
$7.50
Quiet Cut Spindle
Quiet Cut Spindle
Power: 300W, Voltage: 48VDC
Stepper Motor - NEMA 23
Stepper Motor - NEMA 23 (×3)
Holding Torque: 140oz-in - 2014 - 2015, Qty: 1, Machine: non-X-Carve
TinyG CNC Controller
Type: CNC Controller, Version: v8
Waste Board with Threaded Inserts
Size (approx): 500mm 500mm 1/2" MDF, Inserts: M5 Qty 36
Wood Clamp Set
Wood Clamp Set
Type: Clamping System 1, Qty: 4 - don't use
$14.67
Eric Blount
Just to make people aware, the inline power switch (#30359-01) does fit the power supply barrel plug that comes in the Shapoko 2 kit. However, it does not fit onto the jack in the wire that comes in the kit. Either I got a defective switch, or a different barrel plug is needed to accept this jack.
Eric Blount
Bart Dring
Eric, Sorry about that. The Shapeoko uses a 2.5mm center conductor and the switch uses the more standard 2.1mm center conductor. I updated this project and added a note to the product page for the switch. We will contact you about a refund. Bart
Bart Dring
Murat Kilci
Hey Bart. Quick question regarding the Microswitches. Are there any instructions on how to install/use them with the Shapeoko? I want to add those as limiters. Thank you Murat
Murat Kilci
Morten Norgard
Got a kit and the upgrade parts, just the colt plate missing. Guess I can use the drill that in the kit to start with. In the pictures above it's a fan mounted. That fan I can't see anywhere in this list or in the kit. Is it missing in the list or should it be a part of the kit? Morten Norgard
Morten Norgard
Bart Dring
Morten, I am not sure why that was not on the list. I added it. Sorry for the inconvenience. Bart
Bart Dring
Morten Norgard
Same with the 5 mm bolts and nuts, also needs to be added. Motors have other attachments. Also bolts for rollers must be turned and distance washers added t fix the motors.
Morten Norgard
Morten Norgard
Hi What about the wheel that is fitted on the 3 motors for the drag chain? The spindles have a dif. diameter. Drill them or should it be another wheel?
Morten Norgard
Joey Phillips
The Shapeoko full kit is listed in the build, but not selected (presuming it's not included in the price). Can the table-only kit be used since the full kit includes many parts replaced by items in this kit? I am starting from scratch and would like to keep costs low/not have a pile of unused parts.
Joey Phillips
Manuel Huerta
@Bart Dring: I'm a newbie, what are the differences or benefits between the TinyG Controller and the Arduino+gShield? which is better? why?, thanks for the help.
Manuel Huerta
james jones
The link for the fan does not work, how do I get one from the gshield enclosure? And one of the video's shows the drag chain installed on an aluminum bracket, i don't see that here,
james jones
