This package includes the Full Kit + Upgrades. It includes a Quiet Cut spindle, a waste board with clamps, and an electronics enclosure.
This setup is recommended if your goal is to make stuff with the machine. This kit is ideal for businesses, Etsy Sellers, makerspaces, libraries, and schools.
The author’s moral rights;
This picture looks bigger than the cutting area of the full kit (300mm x 300mm x 50mm). Under the bill of materials the size of the waste board is listed 500mm x 500mm. Is it possible the CNC machine pictured is using the 1000mm by 1000mm rails?
Patrick Grantland
1) I have ordered Shaperoko-3 last month.
2) Due to urgently needed, will it be possible to cancel that order and buy
Shaperoko-2(the works 220v.) with upgrade to 1000x1000 mm. now
Tks, Chanchai (Bangkok,Thailand).
Chanchai Chayasombat
Patrick Grantland
