Shapeoko 2 Full Kit mechanical upgrades
Zach Kaplan
Zach Kaplan from Inventables
Chicago, USA
The Shapeoko 2 Full Kit is designed to get you started for as little money as possible. This project has the mechanical upgrades will make your life easier once you start using your machine more frequently.
24v Fan
24v Fan
Voltage: 24 VDC, CFM: 19.8, Size: 60mm × 60m × 25mm, Category: Accessory
gShield Enclosure
gShield Enclosure
Color: Black Anodized Base & Cover
Knurled Aluminum Knob
With crank
Waste Board with Threaded Inserts
Size (approx): 500mm 500mm 1/2" MDF, Inserts: M5 Qty 36
Wood Clamp Set
Wood Clamp Set
Type: Clamping System 1, Qty: 4 - don't use
