brian saban NY, NY
A small candy dish, made mine out of 1/2in white corian from Inventables and lined the pockets with red and white felt
Color: White, Dimensions: 10 in × 12 in, Thickness: 1/2 in, Cut Tolerance: +/- 1/2 in
I used the following settings for Easel. 1/8" Solid Carbide 2 Flute Straight End Mill .06 depth per pass 30 imp
Set your zero and press carve!!!!! I used red and white adhesive backed felt from the local craft store to line the pockets.
