Round Ornament Jig
379 opens
130 copies
Will Winder
Will Winder
Jig and blank for cutting 4" round ornaments with engravings on both sides.
Secure blank for jig
2 minutes
Secure 12″×12″ piece of plywood to your machine.
(Optional) Save Work Coordinate Offset
If you have homing switches, save an XY location in the lower left corner to G55.
Cut jig pockets
Zero the Z axis on plywood blank and cut out the pockets and locating holes for the Jig.
Create blanks
26 minutes
Cut out and tweak the blanks until they fit into the jig. Cut as many blanks as you want to create ornaments.
Secure blanks, engrave front
45 minutes
Secure blanks in jig with a couple wood screws around the perimeter.
Run the operation(s) for the front, zeroing the Z axis on the surface of one of the blanks. Use the same blank each time you zero the tool in case there are slight variations.
Flip blanks, engrave back
45 minutes
Flip the blanks in the jig.
Run the operation(s) for the back, zeroing the Z axis on the surface of one of the blanks. Use the same blank each time you zero the tool in case there are slight variations.
