Play is to 100 points. You have 6 balls in play & take turns spinning, clearing the holes after every spin. Scoring is as follows, each hole is worth the corresponding face value 1,2,3,4 or 5. 4 in a row = 2 extra points, 5 in a row = 5 extra & 6 in a row doubles the face value score.
The author’s moral rights;
Thanks! Play is to 100 points. You have 6 balls in play & take turns spinning, clearing the holes after every spin. Scoring is as follows, each hole is worth the corresponding face value 1,2,3,4 or 5. 4 in a row = 2 extra points, 5 in a row = 5 extra & 6 in a row doubles the face value score.
Ellie
John McWhirter
Ellie
Terri lynne
