Support closed Sunday 4/2
Ripple Jewellery Holder
337 opens
148 copies
519 downloads 8 comments
Wenray Wang
Wenray Wang
Sydney, Australia
This one was inspired by ripples, with the geometry rationalised to create a few compartments for various items. Fusion 360 file can be downloaded at this link: https://a360.co/2NeV9er
Bits used in the project:
1/2 inch flat 2 flute
6mm ballnose bit
1/4 inch flat 2 flute bit
cut_1.nc
Cut 1 adaptive clearing
cut_2_ball.nc
Cut 2 finishing pass
Cut_3_edge.nc
Cut 3 Recessed Edge
Cut_4_Final.nc
Cut 4 Contour cut to depth
General Instructions
G-code is attached for you to load into Easel, or alternatively download the Fusion360 file to create your own toolpaths. One thing to note with the toolpaths I created – because of the thickness of timber I used (32mm) I wasn’t able to cut all the way through with the 1/4 inch bit on the final cutting operation due to vibrations and bit deflection. I ended up going around 25mm deep and cutting the whole piece out of the stock with a jigsaw, and sanding/planing away the edge.
Kevin slagle
I would really like to make one of these. Are you able to share?
Kevin slagle
Wenray Wang
Sure, did you want the fusion 360 file?
Wenray Wang
Chris Beckman
This is great! could you make the project public so we could take a look at it?
Chris Beckman
Wenray Wang
Just made the project public!
Wenray Wang
Tammy Ratzlaff
what bit setting did you tell easel when running the 6mm ballnose bit and how do you tell it, that is a cleanup pass?
Tammy Ratzlaff
Wenray Wang
Hi Tammy - the whole project was made in Fusion360 so all the settings in Easel will be overwritten by the G-Code. Bit settings (feed/ramp speeds etc) are already in the G-code
Wenray Wang
ron williams
unable to download file
ron williams
Greg
Unable to download file too. Please allow and make project public. Thanks
Greg
