Right Arm 4 SDB used with cnc4newbie Z-Slider
63 opens
31 copies
3 comments
Gord Rock
Gord Rock
Longer arm for right side Suckit Dust Boot when used with cnc4newbie Z-Slider.
Cut settings: 800mm/min Feed Rate; 228.6mm/min Plunge Rate; 0.5mm DOC
wayne hall
Just installed the cnc4newbies and see my dust boot needs lenghtened. Found this but do you have the file for the left side? also did you just slot the top on one side or both. Thanks for any help. Thanks Wayne
wayne hall
Gord Rock
Wayne I didn't post one for the left side but if you just flip everything horizontally it should work. Also, I posted longer supports for both the left and right sides. You can find one of them here: https://easel.inventables.com/projects/kR1yP_a6uTeU_YtVFwXiTA I hope this is helpful. …..Gord
Gord Rock
wayne hall
Thank You
wayne hall
