Ridgid R2400 Mount
17 opens
4 copies
2 comments
DamnitJim
DamnitJim
Alaska
Mount for Ridgid R2400 trim router with cutout for gear rack.
Based on Bosh Colt mount.
Black HDPE Sheet
Black HDPE Sheet
Thickness: 3/4 in, Dimensions: 8 in × 12 in
Button Head Cap Screw
Hi-Lo Screw
Hi-Lo Screw
Thread Size: #10-26, Length: 1.00 in, Finish: Zinc Plated, Quantity: 10
$3.99
$3.99
Cut mounts
I cut two mounts out of 3/4" HDPE. If you desire only one, you can just set depth of second mount to zero.
Drill and tap
45 minutes
Leave blocks and tabs intact while drilling mounts.
I used a marking tool to draw centerline down back of mount and the mounting plate for positioning of holes.
Drill two holes (inners) with #19 drill (4.2164mm / .166") for use with M5 tap.
Drill two more holes (outers) to fit hardware of your choosing. I went with traditional wood screws.
On front side, drill another #19 hole lined up with center of rod holder (cutout) and tap.
For the clamp I chose a medium lag screw with hex head and flange. Drill appropriate sized hole for screw and larger drill for the tab part of clamp.
Clean up and mount
Clean up tabs, bore should be smooth for router.
Mount on backing plate, adjust slide as needed, and enjoy!
DamnitJim
Rod holder (lower left of mount) doesn't clear profile of router. Needs to be moved out (left) .45"
DamnitJim
DamnitJim
Fixed position of Rod holder.
DamnitJim
