Remake of "Easel Pro Design Challenge"
62 opens
25 copies
185 downloads 0 comments
Jody
Jody
North Las Vegas, USA
Let’s see your design chops. Enter to win some amazing prizes like a brand new X-Carve!
Baltic Birch Plywood
Baltic Birch Plywood (×2)
18" × 24" × 1/8" Baltic Birch Plywood
Carbide Tip Fish Tail Downcut - 1/8 in Cutting x 1/8 in Shank
$10.99
Carbide Tip V-Bit 60 Degree - 1/2 in Cutting x 1/4 in Shank
$15.91
$26.90
Dogbowl.zip
dogbowlfiles
Straight forward assembly
This was simple assembly. I just used glue on all edges, the 3/4 inch brad nails to tack everything together. Sanding was minimal, just around the edges to soften them. You will notice on the underside, the 45 degree pieces fit only one way to support and strengthen the legs.
Bowl assembly, just used glue then clamp tight on four sides over night. I sandwiched them between 2 2×6 for even clamping force.
I used a Butcher Block oil on everything, to keep it food safe for the pups. Actually 3 solid coats and the bowls would hold water if needed. Don’t really recommend water, I have two dogs so both bowls just hold hard foods.
The two Aliens were just fillers from the cut out of the dog bowl holding spots. Plus gave me an extra chance to use some of the Easel Pro library clip art. Hate to waste wood, so I carved the aliens in both cut out circles. Good decoration for the shop, I live close to Area 51 so embrace your surroundings and let no wood go to waste.
