My goal was to make the DIRESTA stool without glue, with less parts, within an hour, and fit on a 24″ × 24″ build area (make 2 from a quarter sheet). This one was cut out of 0.5" MDF at 75ipm, with a DOC of 0.05in and a 1/8" down-cut end mill and took about 57 mins to complete.
The author’s moral rights;
