Puzzle Piece Picture Frame
264 opens
141 copies
7 comments
Garrett
Garrett
Michigan
Interlocking picture frames designed to hold 4 × 6 pictures. Use just one, or connect as many as you want to create a wall of pictures. There is plenty of unused space to add any additional engraving you would like.
Walnut (×2)
6" × 12" × 1/2" Walnut
Engrave
51 minutes
You will need a 12 inch by 12 inch piece of wood for this picture Frame.
Just put it on your cnc router and cut it out. It cuts out the back side so that there is a recessed section so that the glass and picture can be retained. If you would like to engrave anything on the front then you will need to flip it over after it is cut out.
Finish It
With it cut out, you will need to get a 4 × 6 in piece of glass which you will put in first, then your picture, any type of backing (like cardboard), and then you will need some sort of tabs to hold it
all together.
Hang Them Up
Just grab some hanging hardware and get to hanging all your new picture frames.
Jennifer Peterson
Hi, are you willing to share this publicly? I would love to make this for my grandkids photos. Thank you :-)
Jennifer Peterson
Garrett
I'm sorry. I didn't realize it wasn't public. I think I changed it. Let me know how they fit together, I don't have a cnc router yet to test it.
Garrett
Jennifer Peterson
Thank you!! I will test out this weekend. :-)
Jennifer Peterson
adam
If you change the size, as long as it is a square, will it still fit together?
adam
Garrett
As long as you make all of them the same then they should fit together. I might suggest testing with some scraps to double check first.
Garrett
adam
Two do not fit together.
adam
adam
What outlining cut do you use so they fit together?
adam
