The author’s moral rights;
The diameter of the bamboo frame has a diameter of 5.5 Inches. Cut down the bamboo to an appropriate size. If your machine can fit a 12 × 12 piece of material, you can skip this step.
Secure the Material
The best way to secure your material is to use the “hold down table project” or to screw the material to a waste board with wood screws.
Home the Axis
Place the bit at the desired zero point for all the axis. the origin point for the attached files is in the lower left hand corner of the material.
Create the Cam
I generated the tool paths in makercam.com from a .svg file. The instructions on how to do this are in the video below.
Run The file
Upload the .nc file to a g code sender program. There are multiple free one available, like universal g code sender and g host.
Finish Material
I used a chisel and rubber mallet to break the tabs off the pieces, and finished the edges with some 220 grit sandpaper.
