Portal Cake Coaster
13 opens
1 copy
Brent Bousquet
Brent Bousquet
MA
I wanted to make a set of portal themed coasters all made with different techniques but arriving with the same finished look. This is the one I made with my x-carve. Its good practice for people who want to use the new two stage cut setting and also want to practice inlays. 1/8 flat nose 1/16
MDF Wood
MDF Wood
$3.00
$3.00
Cut MDF
First cut the MDF down to a 4×4 square.
CNC
Now mount the square and cut the cake out with both the roughing pass and detail pass
sanding
Give the mdf a light sand to fix any burrs that my have formed during cutting.
Resin
Pour the resin into the pockets as carefully as possible. The more you spill the more you sand.
sanding resin
Now sand off the excess resin. There will probably be air bubbles that get exposed from sanding.
Lacquer
Apply the lacquer to give the resin back its shine then let dry.
video
Made one? Log in to add yours
