The author’s moral rights;
how do I setup the machine to engrave the letters first and then cut the circles second is their two paths?
William Greenwald
Easel now has 2 steps so you can cut with 2 different bits. Another option is to design the circles with the letters in one workpiece (at the bottom), duplicate it and on one erase the letters on the other the circles. Make sure you carve the letters first, then cut the circles.
Carlos Olvera
It would also be faster to use V-Carving instead of 1/32" bit to do the letters. I did a sheet at a time to make it faster.
Zach Kaplan
How did you avoid all the gross dust that makes the white look grey?
chris kelsch
I used the vacuum, them a tooth brush, and then washed them.
Zach Kaplan
William Greenwald
William Greenwald
Carlos Olvera
Zach Kaplan
chris kelsch
Zach Kaplan
