Poker Card Box
1043 opens
388 copies
1941 downloads 4 comments
Frank Graffagnino
Frank Graffagnino
Here are the steps to build a holder for two decks of standard playing cards. Customize the lid with a family name or neat graphics!
Multiple cuts are required on easel: 1 for the main pocket, 1 (optional) outline cut around the pocket, and 1 cut for a pocket on the inside of the lid.
African Mahogany Wood
African Mahogany Wood (×2)
6" × 12" × 3/4" African Mahogany
French_suits_outline5.dxf
Playing card suits image
French_suits_outline5.svg
pokercardbox_top_underside1_blank.svg
The top underside pocket - 4mm deep
pokercardbox3_pocket_only.svg
The main pocket - 16mm deep
A poker card box project
Here’s an overview video of the project and the steps.
Cut two pieces to 5" x 7"
Cut two pieces of wood that are at least 3/4" thick (such as the African Mahogany from Inventables) to 5″ × 7″. I like to cut the pieces together if possible, but you will be sanding them together to get them to match later.
Mill main pocket
90 minutes
The main pocket to hold the cards is 16mm deep. This will leave some of the card deck sticking above the wood, which means another pocket of 4mm is required on the lid to allow clearance. Also, these depths allow for a felt lining below the card decks to be added.
This can be a long operation. Using a 1/4" milling bit will help speed things up considerably.
Mill pocket outline
To make the main pocket for the card decks more pleasing to the eye and also easier to grab that cards, we will mill out around the outside of the pocket to a depth of 4mm. I used a ball-nose bit to give a bit of rounded edge to this outline, but that isn’t required. You can open up this cut in Easel directly with this link
Mill pocket on lid underside
Switch over to the lid piece and mill out a rectangle on the underside to a depth of 4mm. This gives the clearance for the card deck so that the box can close fully. You can open up this pocket operation for the lid underside in Easel directly with this link
Customize!
This step is completely optional, but with a great machine like the X-Carve or a ShapeOko, why wouldn’t you do some nice customization? Use Easel to mill out shapes or a name, or use software such as F-Engrave to do v-carving as shown in the video. Be sure and test this out on scrap wood first so that you don’t waste the work you put into the piece in the previous steps!
Finish the wood
You may have your own preferred method on finishing the wood. For mine, I stained it and then wiped it off after just a minute or two. Then, after drying, I sanded away most of the stain, just leaving the darker stain inside my writing so as to make it stand out more. Then, I finished with 3 or 4 cycles of coats of polyurethane, then sanding with 220 grit sandpaper. Then, one final coat of polyurethane.
Add hinges and clasp
Add on your favorite hinges and clasp hardware. Keep in mind your screws in the hinges will need to be flat and close to flush in order for the box to open all the way and lay flat.
9
Add felt lining
Print out the main pocket outline and lay it over some felt on a scrap piece of wood. Using an X-ACTO razor knife, cut through the paper and felt at the same time to get a felt outline that should fit perfectly into the box. Use some Gem-Tac fabric glue to glue the felt into the box. Be sure and put some around all of the edges. Use something with a flat rounded edge to push the felt into all of the corners and edge. It will stretch nicely and allow everything to make a perfect fit. Wipe away any excess glue and allow to dry.
Warren Downes
Nice job Frank, i can see that been a very handy Christmas Present.
Warren Downes
Jesse Schmidt
Awesome project Frank... I add a space for a set of 5x19mm dice and give it to my father-in-law for xmass. It came out so good that i decided to make 4 more for some other men in the fam. I sanded the wood to 2000 and used Danish oil... came out great. Thanks for the great idea!
Jesse Schmidt
Frank Graffagnino
That's fantastic Jesse... do share some pictures of it on the forum if you can. I love the idea with the dice.
Frank Graffagnino
