Phone stand/charger
544 opens
60 copies
887 downloads 0 comments
Paul Jenkins
Paul Jenkins
Australia
This is a two sided machining job, with QI phone charger built into the stand for wireless charging
phone_a.svg
phone_b.svg
Intro
Materials
  • 13mm tassie oak
  • QI charger (I used a Nokia charger)
  • Wood glue
  • CA glue
  • 6mm dowel
  • double sided tape
  • secondary MDF waste board (~6mm/1/4" is fine)
Tools
  • XCarve
  • Tablesaw
Drill holes
  • Attach your wood to the wasteboard with double sided tape and load it into the machine
  • Open up the project in Easel, delete everything except the four holes for the dowels.
  • Drill out the dowel holes
Cut out QI charger pocket
45 minutes
  • Without moving the machine, drive in the dowels through the wood and into the MDF
  • Load the project again, delete the concentric circles and drill holes
  • Cut out the wood and charger cavity
Cut out decoration on the front
  • Flip the wood, drive the dowels back into drilled holes
  • Reload the project in Easel, delete everything except the concentric rings
  • Carve away
Make the rest of the stand
  • Using the table saw, cut a 30° bevel on the bottom of the charger,
  • Cut out another peice of wood with the same bevel on one end, about ~50mm (~2") long, the same width as the stand. This is the shelf
  • Cut out another piece of wood with the same bevel on one end about ~100mm (~4"), the same width as the stand. This is the base. Cut a groove in the centre of the base wide and deep enough for the cable to run through
  • Glue the shelf onto the front of the phone charger so the phone has something to lean against
  • Use CA or epoxy to glue the charger to the base – end grain won’t have a lot of strength if you use wood glue, but it can be done. CA is a little bit easier as tape is enough clamping pressure.
