Peterbilt Logo
120 opens
65 copies
564 downloads 0 comments
WorkinWoods
WorkinWoods
Hello everyone this is a Peterbilt logo that was cut out of a piece of Pine I left it unfinished but make one out your own and let me know how you finished it
Birch Plywood
Birch Plywood
Image of Peterbilt Logo
Peterbilt Logo.nc
Easel created Gcode for Peterbilt Logo .125" bit
Setup and Carve
Easel setup:
Saftey Height: .150"
Step over: 40%
Feedrate: 45 in/min
Depth of cut per pass: .0625"
Depth of total cut letters: .110"
Depth of total cut Outside: .748"
material thickness: .748"
Material type: Pine Wood
Bit Size: .125"
Make sure and use tabs to hold the project in place as it is being cut
Also make sure that the letters are carved before the actual piece is cut out
make sure and give yourself enough stock so that you can clamp the project down with out crashing the machine or you can use double sided tape
Made one? Log in to add yours
