Pentagon Nautilus
The Guru
The Guru
I had some scrap wood around and wanted a door prize for a recent town hall. So I created a cutting board with a logo from a work project.
Carbide Tip Upcut 2 Flute - 1/4 in Cutting x 1/4 in Shank
Cutting Diameter: 1/8 in, Shank Diameter: 1/8 in, Cutting Length: 1/4 in
Hard Maple
Hard Maple
6" × 12" × 3/4" Hard Maple
Padauk
Padauk
6" × 12" × 1/8" Padauk
$8.47
$8.47
pentagon_3.dxf
Pentagon Nautilus DXF
pentagon_3.svg
Pentagon Nautilus SVG
pentagon_3.nautilus [nautilus_pocket].nc
Nautilus Pocket
pentagon_3.nautilus [nautilus_profile].nc
Nautilus Profile
pentagon_3.nautilus [pentagon_profile].nc
Nautilus Profile
Outline and Pocket
12 minutes
Attached base board to X-Carve with double sided tape
Load X-Carve with 3" length, 1/8" cutter (2 flute up cut)
Zero machine
Load pentagon_3.nautilus [pentagon_profile].nc
Send to X-Carve
NOTE: Do not remove piece yet
Cut pocket
Load pentagon_3.nautilus [nautilus_pocket].nc
Send to X-Carve
Remove base from X-Carve
Cut Inlays
Attach 1/8" thick Padauk to X-Carve with double sided tape
Zero machine
Load pentagon_3.nautilus [nautilus_profile].nc; send to X-Carve
Assemble
Add glue to pockets
Place inlays into base board
Pound with rubber mallet if required.
Sand and Finish
Sand with 100, 150, 220, 400 grit sand paper
Finish with your favorite beeswax or polish.
