Oregon State Coasters
23 opens
11 copies
Making Manzanita
Making Manzanita
OR
Looking for a fun way to show off your state pride? Check out these state shape coasters for an easy beginner-friendly X-carve project!
Design and carve your coasters
25 minutes
Open file in Easel. Check your wood and cut depth settings. Once you have all this set, run the Carve procedure and carve your state coasters. Most of this step time is carving.
Sand
Start sanding your coasters after they are carved first with 80 grit sandpaper then 150 grit sandpaper.
Stain
Stain the coasters with your desired color and let dry.
Seal
Apply your chosen sealer and let dry. We used polyurethane.
