Octagonal Box
97 opens
33 copies
463 downloads 2 comments
Sam Weston
Sam Weston
This Octagonal box is my entry into the Easel Power Hour Challenge. It can be cut out quickly and assembled with relatively little gluing.
Baltic Birch Plywood
12" × 24" × 1/8" Baltic Birch Plywood
Carbide Tip Compression 2 Flute - 1/8 in Cutting x 1/8 in Shank
Cutting Diameter: 1/8 in, Shank Diameter: 1/8 in, Cutting Length: 2/5 in
$24.17
Gorilla Wood Glue
Gorilla Wood Glue
Gorilla Wood Glue - 4 oz
$24.17
octagonal_box_instructions.pdf
box_assembly.stp
Carving
37 minutes
Carve out the box pieces out of the 1/8 inch wood using the 1/8 inch bit.
Gluing
Attach the box pieces together as pictured in the diagram, use glue as needed. For extra reference, download the provided CAD file.
Stuart G
Can you make this public?
Stuart G
lyle Steimel
Can you make this public!
lyle Steimel
