I designed this one with the new features that allows it to act as a bump stop and a hold down clamp. It also allows for the Inventable screws to work from their clamp system. I also added two nuts for additional clamping power that I am still experimenting with. Hope you enjoy this project.
I made 2 of them and used 3/4 MDF. Love it, thanks!
Stephen Aquila
Nice work!! I will try them later !
What screw lengths do you use to secure them on the board ? Thx
Hendrik Weber
I use several different sizes depending on the thickness of the project you are carving.
Phillip lunsford
I just made 4 of them and they turned out great. Thanks Paw Paw!
Joshua Collins
Will these work for the new board 1000x 1000mm screews
80mm spacing
Kevin Mellinger
I really love the design of these. I made a couple, but after they were done, I realized the distance between the slots where a few millimeters short of the 75 mm distance between the hole on my carve spoil board. Any guidance on what I can do to fix that? Thanks.
Nathaniel Henson
This was a great file!!!!
Came out exactly as expected.
I used inserts left over from my x-carve assembly, instead of the nuts though.
Camille Wing
consider making a video showing how to find your projects in the Easel sandbox, I must have missed in your video saying what the name of this file was. I was looking for 80 mm clamp.
Charles A. Bourg
I have now made several. But resized to 45 mm on center for the 3018 Pro CNC. works better than anything else I have tried with our tight cramped space.
I wish to provide my file to you to share if it is wanted.
How do I post a photo to show you?
Charles A. Bourg
Stephen Aquila
Hendrik Weber
Phillip lunsford
Joshua Collins
Kevin Mellinger
Nathaniel Henson
Camille Wing
Charles A. Bourg
Charles A. Bourg
