Hi, I designed this modern side table that fits perfectly a faux beam that also acts as a stability beam, in these images I cut all pieces with 1 slab of 4×8 plywood piece and put a 45 cut to fit all pieces together seamless. The top you can use anything I used a black walnut slab, enjoy!
The author’s moral rights;
