This minimal planter design is so easy to make with any sheet of acrylic. Go clear for a totally modern look or get funky with an eccentric acrylic style.
Using a modular design system, these planters are fully-functional for any pint-sized terrarium, herbs, or succulents.
The author’s moral rights;
Dennis Ward
Michael Fischer
Scott Willis
Sara Hardy
Zach Kaplan
