Using the X-Carve to help out with some tool organization projects around the shop. I cut a bunch inserts for my tool box drawers & this one is for the tools that I use most when working on the mini lathe and mill – mostly for measurement/set up. I have a video of the whole project on YouTube.
The author’s moral rights;
