Here I used 2 pieces of 1/4" Baltic Birch ply on this board. There are 2 layers of epoxy on the top and 1 on the bottom. Paints are a mixture of acrylics and India inks. Really pleased with how this board turned out, the wood from Inventables is top quality grade and great to work with.
The author’s moral rights;
Keyanna Pulido
