Mid Century Modern Planter Stand
508 opens
239 copies
1054 downloads 4 comments
Benjamin and Erin Tovar
Austin, USA
This is our entry to the #EaselPowerHour.
You will use a 16″ × 16″ × .5″ piece of Baltic Birch.
You will also need a 1/8" Flat Endmill.
It is estimated to take 23 minutes to cut.
Can’t wait to see your planters!
P.S.
I have also included the Fusion360 file for you to customize your own!
Birch Plywood
Birch Plywood (×2)
Gorilla Wood Glue
Gorilla Wood Glue
Gorilla Wood Glue - 4 oz
Planter_v3.f3d
Fusion 360 File for customizing your own (Just edit the sketch)
Set up your 16 x 16 x 1/2 piece of material
You will need a 16 × 16 × 1/2 piece of Baltic birch.
I love the look of the end grain so much.
Load up your 1/8" flat end mill
You know the drill ;]
Machine your parts!
23 minutes
The time estimate in Easel states that these cuts will take about 23 minutes to run.
Assemble!
I added tolerances to the joints so that it should just sit flush and tight together
Check out this Gif to see how it assembles.
Super easy and fresh!
Larry Brooks
when will this project be released
Larry Brooks
Dave Rodman
sort of new here, has this file been shared? Asking ad I can not get it to open in Easel. Thank you.
Dave Rodman
UZIEL HERNANDEZ FERNANDEZ
pliss upload in Easel
Rick Scheck
Can you share this publicly please so that we can open in Easel?
Rick Scheck
