Maslow Bosch POF 1200 sled
31 opens
2 copies
Peter
Peter
A Maslow sled that fits the Bosch POF 1200, including ring mount holes as well as perfectly centred mounting holes for the router, along with a vacuum channel where a hose attaches below the router.
4mm cutter
Use an 4mm end cutter to cut the smaller internal holes
8mm cutter
Use an 8mm end cutter to cut the remaining cuts
Bevel the sled
Bevel the outside of the sled with a 12mm corner cutter
Ring mounts
The ring mounts are positioned with M12 bolts then screwed in place
Router attachment
Remove the plastic plate from the base of the router.
Using five M4 x 15mm hex head bolts with flat and spring washers, attach the router to the MDF
Vacuum
Attach the vacuum raiser and file/sand to fit your vacuum hose
