Make LED LIGHTS blink to music
11 opens
2 copies
656 downloads 1 comment
michael jon barrett
michael jon barrett
LED Vu meter
Under 5$ build!
using the an6884 LED driver
v – bit was used to carve the blank PCB
search creative channel for a great tutorial
here is the link
https://www.youtube.com/watch?v=6gyhOeCgtmA
Circuit Board Blanks
Dimensions: 1 sided FR1 circuit board stock 2 in × 3 in (25 pack)
PCB Milling Bits
PCB Milling Bits
dcd-c-2.pdf
pcb design
circuit schematic
an6884 data
an6884 data
an6884 pinout
carve paths
Secure circuit board blank onto X-Carve.
Use a small v bit to carve the paths.
Set z – axis to .014 inch
set speed to 15 in/min
CARVE!
Takes 9 min to carve paths
drill holes
2 minutes
change out the drill bit for a .03 inch bit.
set cut speed to 30 in/min
carve holes
solder parts
carefully place and solder parts
Made one? Log in to add yours
Roger Shaddick
Could you post a parts list? Thanks
Roger Shaddick
