Longhorn Bull inlay project
0 opens
0 copies
545 downloads 1 comment
WorkinWoods
WorkinWoods
Hello everyonethis is a simple inlay project using a piece of poplar wood and a $1.88 HDPE cutting board from walmart
Birch Plywood
Birch Plywood
Natural HDPE Sheet
Natural HDPE Sheet
Dimensions: 8 in × 12 in, Thickness: 1/2 in, Type: Single color, Color: White
Image of the inlay bull
Bull Inlay project.nc
Easel Gcode for the inlay bull project .125" bit
Setup and carve
Easel setup:
Positive Carving:
Saftey Height: .150"
Step over: 40%
Feedrate: 45 in/min
Depth of cut per pass: .0625"
Depth of total cut: .125"
material thickness: .125"
Material type: HDPE Cutting Board
Bit Size: .125"
Negative Carving:
Step over: 40%
Feedrate: 45 in/min
material thickness: .5"
Material type: Poplar Wood
Bit Size: .125"
You will want to setup 2 different easel files with the settings above so you can cut on the different materials this project has a .01" tolerance for the pieces to fit together so you will have a nice snug fit also make sure to measure your materials with a set of calipers to make sure that you have the correct settings as you might have to adjust according to what you have
