Locker Organizer
84 opens
15 copies
631 downloads 1 comment
Beyond Design
Beyond Design
Chicago, Illinois
A wall mounted organizer with a mirror and pegboard style grid. Small enough to fit in a locker, but could be used by your front door, at your desk, or anywhere else you need.
Black HDPE Sheet
Black HDPE Sheet
Thickness: 1/2 in don't use, Dimensions: 8 in × 12 in don't use
Clear Acrylic Sheet - Cast
Dimensions: 8 in × 12 in, Thickness: 1/8 in, Material Type: Extruded
$4.99
$4.99
locker organizer.svg
Mill hdpe sheet
Mill half inch HDPE with an 1/8th" bit for the main cut.
Use this EASEL link
Mill Acrylic sheet
Mill the acrylic for the top half of the design. A silver mirror acrylic provides a nice mirror surface, or you could use a white acrylic to use as a whiteboard.
Use this EASEL link
Assembly
Once all of the parts are cut its time for assembly. The shelf will fit in using the tabs and slots, no glue should be needed. The mirror can be glued onto the front face after the shelf is in (make sure the shelled out portion is on the back). You can mount this to the wall with double sided tape such as the 3M adhesive strips.
Accessories
The dot grid is designed to the same dimensions of a standard pegboard. You can buy standard hooks from a hardware store to fit into the system. Or if you have a 3d printer available you can design your own accessories!
Made one? Log in to add yours
