Clockwise from top: middle piece, top, LED strip piece that goes directly under the top piece, base for the bottom. Run workpiece 1 then leave material on CNC and cut the 2nd piece. The notches on the bottom piece are for the remote receiver and power cable. “DAYBETTER Led Strip Lights” on Amazon.
The author’s moral rights;
