An easy carve of a Kitchen measuring conversion Chart. Carved out of 1/2" Cherry, using 1/8" bit, 30 degree v-carve and 1/8" for the perimeter. The Drill point at the bottom left use to ensure all multiple carves start at the same location (x=.25, Y = .25). Wife and friends love this item.
Looks Great! How are you getting the contrast between the engraving and the face of the board?
Heather Merlo
It’s the natural contrast from the wood. Being that the face is sanded down to 400 grit yet the engraving isn’t sanded at all. I have found that cherry shows more of the contrast, however they all have once a spray finish or oil is applied.
Glad you liked it!
Shannon Dolese
How deep are you making the cuts in this board
Tracy Thurman
If I am not mistaken I did it at at 1/16” depth
Shannon Dolese
I will check and reply if different then stated. Also it should show in the file
Shannon Dolese
are you using the 1/8 bit first and then going back over with the 30 degree v-bit
Tracy Thurman
This is a very nice project. I'm not sure how the guide holes work when you flip the piece over to carve the back. Do you flip the wood vertically of horizontally?
victor vilao
I'm new to this am I doing something wrong I bring it up but I don't get any off the writing except for your name am I supposed to put it all in
maurice cormier
It is very nice and usefull but i am confused . in the general information you write 30 degree v bit but in the program you select the 60 degree v bit for the number and symbols . Which bit should we use. Thank in advance
Kearney Emile
I have tried both a 60 and 30 degree bits. It depends on the wood species used
Shannon Dolese
Answering
I have a jig that I carved the board to sit in this ensuring it’s in the exact position for zero back and front carving
Shannon Dolese
Heather Merlo
Shannon Dolese
Tracy Thurman
Shannon Dolese
Shannon Dolese
Tracy Thurman
victor vilao
maurice cormier
Kearney Emile
Shannon Dolese
Shannon Dolese
Jason Zolnierz
Shannon Dolese
