Kids Toy Rattle
333 opens
171 copies
752 downloads 1 comment
Jason McGinn
Jason McGinn
Cocagne, Canada
This cute little rattle made from either 1/4" or 1/2 inch stock.
Quantity: 5 (mix of 5 different types), Shank Diameter: 1/8 in, Cutting Diameter: Varies
$25.00
Red Oak Plywood
Red Oak Plywood
$25.00
Watch the Video
The first thing I recommend, is watching the video for insight and important aspects that can’t be reached through a static document or text.
Setting up in Easel
In order to setup the default cut layout, simply click the “Open in Easel” up top
Cut out the parts
If you used tabs to cut your parts, saw these off and sand smooth.
If the re-saw method will be used, please follow demonstration on video at 4min 50sec
Cut Dowels and Sand
Using ½” dowels, cut two 3” sections.
Using your drill, put the dowel into the chuck.
Use the drill to sand the dowel to a slightly loose fit to the wheels and a loose fit to the car holes.
Assembly and Glue up
Using the dowels glue one wheel to each and let set.
Put the dowels through one side of the car and lay flat.
Run glue around the body and drop in some kernels to fill only one cavity and then take some away.
Put the body together and clamp while keeping the dowels in place for alignment.
Once the glue up is clamped and good, remove the dowels to avoid them from gluing to the body.
Let sit for at least 4 hours
Glue remaining wheels onto dowels, cut and sand any remaining dowel
Sanding and Finishing
With 100 grit sandpaper and moving up through to 320, all the edges are worked down and the surface should be completely smooth for a babies touch.
The inside isn’t too important to sand, but I’d recommend using at least a 150 for better gluing.
Jeremy Richards
Looks good man! Loving how it turned out.
Jeremy Richards
