I needed to make seating for the table I had built for my son. I was able to get three of these stools out of one sheet of 1/2" ply. This kept my cost for all three stools below $30 and they are stackable so they will take up less space when not in use.
The author’s moral rights;
kody schaefer
JJ Ford
Jason Maudie
JJ Ford
Jeff Richmond
