Jarrah Oak Butterfly Box
1029 opens
358 copies
10 comments
Andrew Petzold
Andrew Petzold
This is a box I made completely using Easel. I used the offset tool and the inlay tool to make this file. If you need any help with cutting this project message me and I’ll help you.
Red Oak
Red Oak
6" × 12" × 3/4" Red Oak
Lawrence Kelley
it's only letting us download 1/2 of the project ?? can you please check to ensure we have both side :-) can't wait to try it out :-)
Lawrence Kelley
Andrew Petzold
It have multiple worksheets in one project there is an arrow to show that on the bottom when project it open.
Andrew Petzold
Anthony smith
mb a dumb question,,,, but what is the point of multiple pages? easier than all one?
Anthony smith
Andrew Petzold
Anthony smith, I made it on multi so I can test each cut separate and make sure the fit was perfect. Probably could move it to one worksheet now. 1-3-2020
Andrew Petzold
Gene Trujillo
I made one of these and I really like it. I would like to know how to make it bigger (5.5" Wide).
Gene Trujillo
andrewlarsen
ohh yeah
andrewlarsen
Becky Binder
well tried to make it but the lid does not fit, it is the same size as the bottom box
Becky Binder
Jody Chaffin
I want to make this box larger how do I change to fit the lid and the base I want go about six inches
Jody Chaffin
Josh Meehan
Thanks for sharing this. We tried to make it bigger but the top does not nest on the bottom.
Josh Meehan
Scott Johnson
It seems that one of the pockets in "TOP one Cut" does not match the same pocket in the rest of the work-pieces. The simulator makes it seem like the middle will be too thick. I copied that pocket from a different workpiece while deleting from one cut and it looks like a better fit.
Scott Johnson
