Interlocking Brick
149 opens
60 copies
Scott Corey
Scott Corey
New Jersey
This file will carve (2) bricks, and you will have to flip the workpiece 180 degrees in the ‘X’ direction.
Double check the size and depth against your work piece. To reduce carve time you can decrease the depth of the cut on the underside of the brick.
