Holographic Lights for your Google Home Mini
71 opens
20 copies
753 downloads 5 comments
Scott Hatfield
Scott Hatfield
Overall, the Google Home Mini is a great smart speaker. But, if your Google Home Mini is far away, or at the wrong angle, it can be hard to see the upward-facing lights. In this project, we will make a clear acrylic stand that makes the lights appear to hover over the top of the Google Home Mini.
Light Guide Acrylic Sheet
$15.94
Add to Cart
$15.94
Upper_Frame_Drawing_v1.pdf
Upper Frame Dimensional Drawing
Lower_Frame_Drawing_v1.pdf
Lower Frame Dimensional Drawing
Lower_Frame_Acrylic_v1.step
Lower Frame 3D model
Upper_Frame_Acrylic_v1.step
Upper Frame 3D model
Cut out the Design
59 minutes
The first step in creating your own holographic light stand for your Google Home Mini is cutting out the design from Lucite. Lucite is a type of acrylic that is specifically formulated for transmitting light. The holographic stand is an application of edge-lit signage and Lucite works great for this purpose. If you don’t have Lucite, clear acrylic works as well.
Using your X-Carve or Carvey, cut out the design using the default settings from Easel:
  • Feed rate: 40 in/min
  • Plunge rate: 12 in/min
  • Depth per pass: 0.03 in
Assemble the Stand
2 minutes
Assembling the stand is extremely easy. The two parts, the Upper Frame and Lower Frame simply slot together. After placing your Google Home Mini in the center of the Lower Frame part, place the Upper Frame on top. The LED lights on the top of the Google Home Mini should be directly under the Upper Frame.
Rene Pedersen
that´s truly awesome, is it possible for you to share the project publicly, so it can be opened in easel? I would love to make this for my own home speakers
Rene Pedersen
Bjarne Tondersen
This project has not been shared publicly
Bjarne Tondersen
Tim Shilson
Love your design, but it seems that your design here is strictly to show what you have done, Are you planning on releasing the .SVG files anytime in the future? This would make a great gift item as the Google Mini is becoming such a popular gift item as well.
Tim Shilson
Erik Nauman
I too would love to make this but you need to share your design publicly. I don't know what to do with a .step file.
Erik Nauman
Troy G
can you share this publicly???
Troy G
