Holiday Ornament
451 opens
182 copies
729 downloads 0 comments
Will Winder
Will Winder
A festive ornament that you can decorate with a message.
Cutting Diameter: 1/8 in - 2013 - 2016, Shank Diameter: 1/8 in, Quantity: 10
Cherry Wood
Cherry Wood
6" × 12" × 1/8" Cherry Wood
$7.14
¼" Bit Set for V-Carving
Carbide Tip V-Bit 90 Degree - 1/2 in Cutting x 1/4 in Shank - 30342-01, Carbide Tip V-Bit 60 Degree - 1/2 in Cutting x 1/4 in Shank - 30342-02
$7.14
snowflake.svg
A snowflake pattern with an open center to put your message.
Design snowflake
Open the SVG file in Easel and add any text you like.
Cut out snowflake
I chose to use a 1/8" bit for the profile and a V shaped bit to get detail in the text.
Paint ornaments with your family
We used washable finger paints. Once the paint dried 3 coats of polyurethane were applied to seal in the washable paints.
A fine paintbrush can be used to add detail to the lettering.
Add hook and ribbon
With a drill press or hand drill, add small holes to the top of the ornament. A 1/32" drill bit worked well for the eye hooks we found at the hardware store.
Tie a ribbon to the hook to finish the ornament.
Made one? Log in to add yours
