Heart shaped box with lid
3035 opens
1588 copies
10 comments
Donald LeBlanc
Donald LeBlanc
Eastvale, California
This is a small box that I made for my wife for Valentine’s Day. It is made from 1 3/4" Purple Heart and the lid nests into the base. My next version will have the top hollowed out for more room but I wanted to get this posted in time for Valentine’s Day.
Open in Easel
Open the project in Easel and scale to fit your material.
I made mine out of 1 3/4" Purple Heart.
Cut out shapes
I used an 1/8" upcut spiral bit but the design should accommodate a 1/4" bit with no problems. I have one on order and will test it out when I get it and update this step.
Sand
As with all woodworking you will need to sand, sand, sand… I plan on rounding over the top lid to make it look more heart like. I will update this once it is completed. I wanted to get this posted in time for Valentine’s Day.
Stain/Finish
Apply the stain or finish of your choosing. I used Tung Oil
Kurt Canez
IfI want the box deeper then do I just cut an additional piece and go all the way through? Then glue together?
Kurt Canez
Donald LeBlanc
Kurt Canez, I would glue 2 pieces of wood together first, and then carve it out as deep as the bit could safely handle.
Donald LeBlanc
Tim Kipp Sr
I found the local DIY store has 1 inch thick pine stair treads. cut to a 9inch length - Worked perfect for the bottom and I was able to go .75 deep with the pocket. Then I used 1/2 thick pine for lid.
Tim Kipp Sr
Robert L Bragg
Unable to copy project, get error
Robert L Bragg
Robert L Bragg
Was able to copy on third try
Robert L Bragg
Jonathan Ruiz
file worked great for me. I simply copy and pasted it into my project. changed depth as necessary and it cut great. my wife loves it. Hickory heart shaped box
Jonathan Ruiz
george longworth
i made one for the wife a while back using a piece of mahogany and some pine
george longworth
Jeanna Pizzino
Hello. I have been wanting a heart shaped jewelry box made out of purple heart wood and this is just what I want. Would you please make one and sell it to me?
Jeanna Pizzino
Chase Creange
The lid isn't snug. It's got like 1/16 play on all sides. I followed directions exactly. Nice design. Thank you. The lid is my only issue.
Chase Creange
