Hand Clock
640 opens
189 copies
Charles Dearing
Charles Dearing
Gatesville, united States
A clock design inspired by M.C. Escher artwork
Maple Plywood (Rotary)
Type: Plywood, Wood Type: Plywood, Species: Maple, Thickness: 1/2 in, Dimensions: 18 in × 24 in
Hand of Time
1- Choose your material of choice. I chose Maple ply with mdf core.
2- Put the thickness, width and length into Easel. For me it was 3/16 thick and 29 1/2 × 18 3/4.
3- Choose your depth per pass. I am using a DeWalt 611. My bit was 1/16 2 flute fish tail. Depth per pass set at 0.028 in.
4- Set the feed rate. I went with 28 in/min.
5- Make sure the bit in your desired home position and make the bit “kiss” the surface.
6- Go through the portion of the Easel carve setup to confirm all steps you’ve completed.
7- Hit Carve and go!
8- When completed, sand and finish to your liking.
9- Add your desired clock movement.
Enjoy!
