Halloween Sleepy Hollow Sign
John Holinka
John Holinka
Austin, USA
Three G-code files to make a Sleepy Halloween Tavern and Inn sign.
Part 1 – V-bit of text
Part 2 – Sign shape with 1/8 straight bit
Part 3 – Headless horseman image with 1/16 fishtail bit
Suction Cup Tape
Suction Cup Tape
Color: White, Form: Sheet, Dimensions: 210 mm × 297 mm × 0.50 mm
$15.99
$15.99
Sleepy_Hollow_Sign_125_mill_part2.nc
1_16th bit Headless horseman
Sleepy_Hollow_Sign_125_mill.nc
1_8th bit Sign Cutout
Sleep_Hollow_Sign_Vcarve.nc
90 degree bit Sign Text
Sign making instructions
Set up for .57 inch material. (Cedar fence pickets)
Used 2 6-inch wide by 8-feet long cedar fence pickets.
Cut into four 20-inch pieces.
Joint edges on table saw or hand plane. Or simply glue together roughly.
After glue dries clamp or tape down panel in Xcarve and run each of three files.
If material is too thick cut off remaining to coping saw, band saw or other means and sand flat edges.
Paint or finish as desired.
