Grumpy Cat Plaque
WorkinWoods
WorkinWoods
Hello everyone this is a small project that I made of grumpy cat I tried using a glow in the dark paint to fill the voids but i am not sure that I like it lol
Birch Plywood
Birch Plywood
Image of the grumpy cat
small grumpy cat.nc
easel Gcode for grumpy cat
Setup and Carve
Easel setup:
Saftey Height: .150"
Step over: 50%
Feedrate: 25 in/min
Depth of cut per pass: .031
Depth of total cut: .050"
material thickness: .25"
Material type: Birch Plywood
Bit Size: .0625"
