"Gears of Creation" Sign
207 opens
45 copies
3 comments
Casey Wood
Casey Wood
“Gears of Creation” was a concept I thought about when realizing all the amazing things created by the motors and gears used to create the X-Carve. I used a sprocket file from Inventables “Pro Design Gallery” and designed a connecting bracket with logo all sitting atop a motor to drive the sprocket!
All Info and Instructions for "Gears of Creation"
160 minutes
All the files for this project can be made with plywood, like the Easel project above, but my images of my finished product was done using aluminum sheet, MDF, Plywood, and HDPE from Inventables materials. If you would like to create it as I did, and of course you could change out their logo for your own, use the Easel file links below.
List of Materials:
2 – Washers
1 – Screw
1- Plastic Tube 1” Long with .25” OD (Any Hardware Store)
1 – Flange Plastic Tube approx 1” Long (Any Hardware Store)
Zipties
Plywood (1/8” 18×24):
Material:
https://www.inventables.com/technologies/baltic-birch-plywood—2
MDF (1/2” 12×24):
Material:
https://www.inventables.com/technologies/mdf-wood
Easel File:
https://easel.inventables.com/projects/HsrXbkmGy4XQmEQK7gL5gQ
Black Aluminum Sheet (12×12)
Material:
https://www.inventables.com/technologies/black-anodized-aluminum-sheets
Easel File:
https://easel.inventables.com/projects/Sj98tVpiPYnPVlNLGck54w
Yellow HDPE (1/4” 12×12):
Material:
https://www.inventables.com/technologies/two-color-hdpe-yellow-on-black
Easel File:
https://easel.inventables.com/projects/7BZTNOMCTztbbrV3UM0Vyg
Electric Motor:
https://www.amazon.com/gp/product/B07TFDPZP7/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
LED Lights with Remote (pick your color and lighting effects):
https://www.amazon.com/dp/B089XVPTKC?psc=1&ref=ppx_yo2_dt_b_product_details
Sprocket Bolts:
https://www.rockymountainatvmc.com/parts/primary-drive-sprocket-bolt-and-nut-kit-p
devin J crowe
do you have any more in depth pics on how you made the back plate spin while the front logo sits Still
devin J crowe
Warren M Radcliff
Beautiful but just like Devin Crowe, I too would like to know how you made the front logo sit still.
Warren M Radcliff
