Fun Wood Daggers
102 opens
51 copies
7 comments
Drew
Drew
USA
Some fun wooden daggers to play around with or use as decorations, or do whatever you want with I suppose lol. The center raised piece in the middle of each dagger is an inlay. I do plan on making more of these designed differently, thought these turned out kind of cool, so I posted them, enjoy!
Drew Kasel
Really clever and well done. But FYI that you didn't actually share the project, so nobody else can open it.
Drew Kasel
Drew
Thanks for the comment, I’m not really sure why I’ve had so many problems with people not being able to open my projects, I think it has something to do with Inventables. I just looked at it and everything is set properly
Drew
Andrew Schulcz
I think it’s on inventables end. Try posting the link here. File> Share>shared with link. That’ll help. Thanks!
Andrew Schulcz
Drew
Thanks for the input Andrew, I’m going to write Inventables an email regarding this matter and see if there’s anything they can maybe do about this first since this is happening to seemingly all of my projects and if that yields any positive results, I’ll try your method, thanks again!
Drew
Drew
Email sent, I’ll have a permanent solution soon hopefully to all the projects this is effecting. Check back soon for updates!
Drew
Drew
Drew
Drew
I've got in contact with tech support over this issue and I've made some changes so if anyone can try and open the file now and let me know if it works that would be great!
Drew
