Frame Bin - AJ Cox
291 opens
118 copies
3 comments
AJ Cox
AJ Cox
The inspiration for this project is that cylindrical bins are a pain to use with plastic shopping bags and I wanted a more elegant solution than just hanging a bag from a hook.
For context, I don’t condone single use plastic bags, but in my city recycling is collected in them.
Gorilla Wood Glue
Gorilla Wood Glue
MDF Wood
MDF Wood
Machine
Machine the parts on your x-carve using the beautiful and intuitive software provided by Easels.
Assemble
Put together the machined parts as shown in the attached image.
Antonio Hernandez Menchaca
You should use plywood for your design instead of MDF. For the rings to fit around the large "U"s you have to flex them bit, mdf is not flex resistant at all so it might break.
AJ Cox
Thanks Antonio, I certainly considered using ply, but I felt like with such a wire-frame structure I would want the form to blend together a bit through the materials and plywood has such strong 'direction'. As inflexible is, the part should have more than enough give to allow assembly.
AJ Cox
Simone Bernabei
Hi, is it possible to do it with another CNC? I'm new and have you the sag file to help me try to do it?! thanks Simon
Simone Bernabei
