Flip Milling Boxes on X-Carve (with v-bits!)
166 opens
58 copies
7 comments
Mo Stych
Mo Stych
Flip milling involves carving both sides of your material. This Easel Live class shares tips for setting up your Easel file for flip milling. It also includes a jig to align your material easier.
We teach these techniques while making an engraved box with a v-bit in Easel Pro!
Watch Easel Live
40 minutes
We’ll walk you through all the steps you need in order to design and carve your box with Easel Pro’s v-carving features.
Plus, we’ll show how to use the jig for when you complete your flip mill!
Rick Frantz
Thanks for the video and another way to make something unique.
Rick Frantz
Michael Anthony Sullivan
Very helpful. Where can I find the Flip Milling Bracket you mentioned?
Mo Stych
Michael, you can find the Flip Milling Bracket in the final workpiece of the Easel project. Click the 'open in Easel' button (above) or "use this link.":https://easel.inventables.com/projects/QfhCXCqYn6v9SfaM9bMc2g
Mo Stych
Raymond Fuller
What size screw do I need for the clamp?
Raymond Fuller
Mo Stych
The screw can be any length, provided it is an M5 screw (the same as the X-Carve clamps). Hope this helps!
Mo Stych
Jason  Posey
The bracket does not support the post Nov 21 x carve waste board holes. By my calculations it would be 3.125 in center to center on the hole because the holes are 3.375 inches apart from outer edge to outer edge then minus 1/2 of the .225 twice for both holes plus or minus .10 of an inch
Jason Posey
Jason  Posey
I ran out of space above, but thank you for a wonderful video. You are doing great things! Some one please check behind me and comment if I am correct. I was asking not telling ?
Jason Posey
