EVA foam shadow board
Victor yoshimoto
Victor yoshimoto
Create shadow boards for tools
Place tools on a light box and take a picture
3 minutes
Place your desired tools on a light box and take a picture. I made mine with a box, led light and white paper.
Use the image vectorizer
Open a new project and select image vectorizer
Select the picture
2 minutes
Select the picture and play with the settings until the image capture satisfies your needs
Enlarge the picture
2 minutes
If you know the length of one of the tools, enlarge the image until it matches. After this is done, you can delete the border. You can use the dimension of the ligthbox as a reference. I had to enlarge the image a tiny bit to compensate for the image from the camera.
Clean up your image
2 minutes
If you are not satisfied with the image quality, reload it again or take a new picture
Add finger grooves
My preference is to add finger grooves to quickly grab the tools. Make sure they are big enough for your finger to easily grab the tool
Prepare your EVA foam
3 minutes
I use EVA foam (floor mats) for shadow boards. They are easy to cut, and available everywhere. Just choose the color you like best. Cut it to size and secure it
Start carving
The time depends on your settings. I usually keep the edges of the foam to help sure the foam. You can cut them later
9
Finish your shadow board
When done carving, you can use a heat gun and slowly go over the edges. This will melt the foam burrs.
10
Final Product
Enjoy. After a couple of tries, I was able to figure out the correct ratio from my camera
Mircea Bascuti
You forgot an essential detail... What cutter did you used?
Mircea Bascuti
Eddie Fowl
Love it!
Eddie Fowl
Kevin Bond
That is awesome, thank you for sharing the step by step directions
Kevin Bond
